Casey in Ky
Ran fine, shut it down after loading a load of hay. Came back a couple days later and no crank. Battery is hot hot, have jiggled the pto safety switch and the gear shift levers and nothing. Couldnt fully see the fuse panel but couldnt find anything blown in it. It appears the starter solenoid is ontop of the starter, which puts it directly behind the sediment bowl and fuel filter, so crossing over the starter is a no go. Any suggestions on where to start? No click, grinding, spinning, or other noises, just nothing when turn the key. Dash lights do go off when turn the ignition key. Thanks
