Ford 5000 Coolant Drain
jrslv
Guys,
How to completely drain an engine's coolant system? Is there a water drain plug on the engine block itself?
My radiator blew this sping so I took if off my [b:df664dd6e4]1965 Ford 5000 Diesel[/b:df664dd6e4] tractor. After I put the repaired radiator back, I put deionized water just to test it. Now I need to replace the water with a real 50/50 antifreeze mix. But how do I do that properly?
I drained the system by disconnecting the hose from the radiator's bottom (intake) pipe. I thought this is the lowest point in the system, so it should be empty now.
But I could only add 2.5 ga of antifreeze and the radiator was already full (at just an inch below the filler pipe). Compare that with 3 full ga of water I poured into the radiator when it was dray, and it wasn't even full as the water was barely covering the fins inside.
It seems like there was still 1 ga of water left after I "drained" it.
What do I do now? Drain it again and add antifreeze in the hope diluting the remaining water down to acceptable level?
Thanks,
Jaroslav
(quoted from post at 23:38:27 09/17/23) Guys,
My radiator blew this sping so I took if off my [b:d0a81a4bd4]1965 Ford 5000 Diesel[/b:d0a81a4bd4] tractor. After I put the repaired radiator back, I put deionized water just to test it. Now I need to replace the water with a real 50/50 antifreeze mix. But how do I do that properly?
Thanks,
Jaroslav
As Bern indicated the block drain will be the lowest point.
Run the tractor up to operating temp as is. Maybe a couple of times. Using a coolant tester, check the freeze point. If it is not where you want it, drain the coolant, and adjust with more antifreeze, then refill.
Don't overfill. Should end up just a bit over the top of the tubes.
Hopefully you have used proper, diesel rated coolant. If not, time to correct.
(quoted from post at 13:24:47 09/20/23)
(quoted from post at 20:18:23 09/18/23) Any diesel rated anti-freeze should be fine.
Specifically look for SCA additives to control cavitation air bubbles.
Here's some reading for you
Yeah, mine has the SCA additives.
Also, I found the drain - it was right there - in clear sight - with an electric block heater inline :)
Thanks for the help guys!
