Ford 5000 front bracket bolt size
larw
Hello tractor people
I have a '69 Ford 5000 and have found a weight bracket to go on front.
However, I am uncertain on the bolt size required for the 4 threaded bolt holes on the front end.
I think they are 5/8"-11, can someone confirm please.
Thanks in advance
Lachlan
(quoted from post at 20:39:10 10/13/17) ptfarmer & Shaun Wallace,,,,,Welp, y'all REALLY "cleared' that up for larw.
I can put a 5/8" bolt in mine, and its loose, my 4500 being an industrial maybe they are bigger than what the agricultural tractors use.
4 sticks of the yellow tipped course thread all-thread rod fit it fine. Can't remember what size that color code meant tho....
Paul
ptfarmer- "When in doubt I get 4 of each...."
So, you don't really know the answer? Why did you "guess"
at the question???
(quoted from post at 21:19:03 10/13/17) ptfarmer- "When in doubt I get 4 of each...."
at the question???
I didn't guess because that what mine takes, and according to the parts book it calls for 3/4" 10 (course thread) to hold the front weights on for the 3550-7100 tractors.
Thank you for the help gentlemen.
I'll grab some 5/8"-11's next weekend and give them a shot.
Also noted is the Grade 8 comment, will make sure they are and pop some loctite in to assist.
Again, appreciate the great help from this forum.
Enjoy your weekend in the US of A or whatever part of the world you are in, mine has been pretty good but nearly over here in Australia.
Cheers
Lachlan
I used all-thread rod. The precut short size was perfect over here, didn't even have to make my own cuts.
Threaded it in nice and deep, then put on a washer and nut, so I could lock it on nice and tight to the tractor.slip the weights on and tighten up.
Can't remember if I put a nut on to hold each weight in place. Anyhow everything is nice and solid.
The allthread really worked nice. (Rod that is threaded all the way, no ends to it.)
Paul
They are not 5/8 11.
Absolutely, positively those are 3/4 10.
The 5000, 4400 and 4500 all used the same bolster and power steering which was kinda doohicky.
3500 and 3550 used the same bolster but different PS.
I too decided to use the holes on my 3000. First thing I did was to spend the money for a tap and chase the threads before using. You'd be surprised, well maybe not, what came out of the holes.
will be a good idea to pick up a common tap in that size and chase the threads first with some oil. Then I would install with anti-seize.
As some of the others said getting a tap to clean the threads would be a good idea, the threads tend to get full of paint, and other stuff. Like extra bolts, it never hurts to have tap(s) in your tool box, never know when you may need it again.
Hey there all,
I will buy both tap sizes as well as both bolt types, thanks for this tip.
Weekends almost over, sitting back with a few cans and enjoying the aussie sun. Liv'in it large.
Thanks again
Lachlan
at the question???
Many people recognize the value of time, and cost of trips to town, as well as a stock of nuts and bolts on premises.
Gents
Thought I would follow up on the great help and show a happy snap of my dodgee work.
Ptfarmer & Shaun: ended up 3/4"-10 grade 8 thread.
Paul: picked up a 3’ rod and cut to size, cracker suggestion.
There’s a lock nut inside the frame then doubled the top nuts.
I now have a sense of steering.
The bracket is not a Ford one so I have put them on this way. This is until I sort a fabricator to cut away some of it so the proper side weights with the bolts can be fitted. Hence I also added the little chain things just in case the weights flip up......Plus I was having a bit of fun too.
In between the locking rod are 2 nuts to keep the space as the bracket has a tongue sticking up in the center.
Again thanks for the great help, enjoy your weekend.
