Hi all - I parked our Ford 5000 (c. late 70s) last week after getting the last of our hay in, and when I went to start it today, it was acting like it wasn't getting fuel. It would close to firing, but not quite. I was near a hill and was able to try to roll start it for at least 150 yards with no luck. I also bled it with no luck. I started working through the fuel system, and everything seemed to be OK. Finally, I found that the fourth injector at the top of the injection pump is not working (pictured). I opened the cam box, and it was definitely low on oil, and likely was for some time. It looked like that part of the pump was moving as it should, but it was hard to tell without a better light. Is there any chance it is clogged and could be flushed with air (and then re-bled)? It looks like the top of that injector part twists off, but I could not get it to budge. I've also seen some posts about the excess fuel button, but I can't tell what it is/isn't doing. Could I be missing something? Any advice would be much appreciated!
