Jeremy Anderson
Hello folks, I am working on a Ford 5000 (5200), it has the simms inline pump, the original pump had stripped threads on the drain plug and fill plug for the oil reservoir, the owner decided to remove the pump off of a tractor that had been sitting in the barn for a while to replace it with. I got the pumps swapped and all the air bled from filter housing and the pump but my problem is there is no fuel coming out of the injection pump to the injectors while cranking. Yes, the fuel shut off lever is all the way forward. I am at a loss here. Any advice would sure be appreciated. Thanks!
