Ford 5000 leaking trans fluid
Bramdad
My ford 5000 got stuck in a ditch... then in flooded. Engine oil was clean. I drained the trans and put 5 gallons of fresh fluids in and she started leaking from the plate between trans and engine. Thoughts?
It's likely just residual water/oil in the clutch housing. Monitor it and it'll likely slow down and stop. Also jiggle the cotter pin on the bottom to help drain the cavity.
Bramdad,
The Trans and the rear end/Hydraulic section are separate sumps on that tractor.
The Trans only holds 12 Quarts, you put in 20. I hope the clutch didn't get wet????
If you need an operator manual, the whole manual is available for download on the "other" Tractor web site.
I can't link to it, this site doesn't allow for it.
Just search for "N"
then the word "Tractor"
then the word "Club".
Go to Manuals and scroll down to the tractor section.
Keith
(quoted from post at 09:20:54 06/26/19) Bramdad,
I might be mistaken, but I thought that the later 5000's with dual power had a common sump between the trans and rear end?
That's why I didn't reply earlier. He didn't say what he had.
But, I looked at the op manual on that site and saw 12 quarts.
The OP also said he put the oil in the trans. The fill for the common sump is the rear end if I remember correctly.
It would explain the OP problem if he put 20 Quarts in the Trans, correct?
Keith
