swatkins27
New to the group and wanted to give thanks in advance, I'm hoping someone can help me out with am issue on my Ford 5000. So this tractor set up for about a year then after my dad passed I started getting it back to running. The off road fuel had turned to sludge so first thing was new gas tank, float and petcock filter screen then cleaned the fuel lines out which led me to the injector pump and I found the fuel rail and pistons gummed up so after cleaning all of this I finally got the rail working properly. I bled all of the injectors at the engine and with a little prayer the tractor started up and ran pretty good, I let it stay running in my shop for several minutes when it all of a sudden started to over rev finally got the tractor to shut off by putting it in high gear and bogging it down with the clutch and brake which I know is not good but its the only way to shut it off. I drained all of the water from the injector pump, flushed with a lot of oil then refilled with the proper weight oil. Now the tractor will idle half way decent but will still run away, when this happens shutting off the fuel does nothing, I have to bog it down in order to shut it off. I have noticed it seems to happen most when the governor would kick in like going up an incline or running the bush hog. I'm wondering if its sucking air or maybe has trash in the governor that causes it to stick??? I have not sprayed around the engine with ether to find any air leaks but that is on my to do list this coming weekend. Other than that what could be other causes of this running away?
