ford 5000 pto problem
rlh0505
i used my 5000 to pull the baler the pto works fine unless i shut it off.once its turned off it will not come back on. any help would be great. thanks
guesses..
leak on suction line to pump
leak on small line from pump to pto valve
leak on sealing rings at pto support feed and/or worn pto support feed assembly
leak in pto clutch, oring or internal housing..
weak pump with low pressure especially after hot..
dual power leak if equipped.
remember the pump has two stages, one for the pto and dual power, the other for the hydraulics.
