Ford 5000 Simms pump
If it leaks there most likely the drip tube/bolt needs cleaned. Later pumps don't use that breather anymore. Might check and see if the supply pump has a bad diaphragm which will then fill the cam box with fuel too. Best change the oil in the pump also.
