Serial # will be on the flat spot just aft and above the starter - on the bell housing. Post all the numbers that you find there and the good folks here will decipher it for you
PS pressure should be in the range of 800 to 850 psi I think. What is wrong with the steering?
thanks for the info. power steering is not working. cylinder has been rebuilt but didnt help any. with front wheels off the ground it seems fine but with weight on the wheels it does nothing. thanks for the info. winn
pwr stg pumps can be as low as 500lbs and as high as 1100 lbs iirc... the 5000 was around 600 iirc on early and a bit more on late.
