ridgeandvalley
OK. I posted earlier about a NH 469 haybine I was having some problems with, and was trying to decide if it was worth it to fix it. I only cut about 7 - 8 acres of grass hay at a time. I have a Ford 501 sickle mower that I picked up as a backup a couple of years ago. The first time I used it, was on a second cutting and the grass hay was pretty fine and thin. I had a lot of clogging and frustration, and finally got a neighbor to mow my field for me. Kind of regretted buying it. Before giving up on it, I took some time to watch some videos and look over the user's manual and I made some adjustments to it. I've used it for first cutting a couple of times since then, and it's done a nice job. Used it to clean up some fence rows and an old field that was overgrown in weeds and thistles and it mowed it right down. Right now my haybine is not operational and I'm planning on using the Ford sickle mower for my second hay cutting, but I know the hay (mostly orchard and timothy grass) will be much shorter and finer stemmed than what I've been mowing. Does a simple sickle bar mower handle second cutting grass as well as the taller, coarser first cutting? I'm just not sure if my frustration the first time I used was due to the fact I was new to it and it wasn't adjusted right, or if it was the nature of the second cutting grass. Thoughts from those more experienced with this old equipment?
