ford 515 sickle mower
JimBaird
So I recently picked up a decent Ford 515 sickle mower. One of the grease points in the owner's manual is to take off the cap on the drive housing and grease the bearing under the cap. When I pulled the bearing out and cleaned it I found out it needs replaced. My problem is figuring out what # the bearing is. The bearing part # for ford is #c1vv-1202-19. There are two Timken #s on the assembly. The rubber seal on the bearing is LM48500L and the bearing itself has a # that looks like LM48548. So I have tried a distributor for Timken and said he though the bearing I need is a LM48500LA-902A1 but Timken is out of stock until June. They have one of these listed on amazon of all places. I have e-mailed Timken to verify the number differences but they haven't responded. Is there any way of cross referencing the Ford # to make sure I get the right one? Thanks for any help.
WoreOut is right, the C1VV part number you mention is for the cup only. The original parts manual calls up that number for the cup, while the cone (bearing) is 86052. That 86052 number now subs to the 851494 number WoreOut mentioned, which is the cup/cone/seal combined set. If you Google these part numbers, you'll find cross-reference/interchanges, but by the time you cross-reference and source the cup/cone/separately, I think you'll find you're not saving anything over just buying the complete 851494 unit from CNH.
