yoteman
have a ford 550 backhoe,cant find the hydralic filter on it could it be in the frame work of the frontend loader?
You've got a number missing, your tractor is a 3550, not a 550
It uses a model 735 loader
The filter is located in the bottom of the leg that the fill cap is on, it's on a plate the bolts to the bottom of that leg
Item 22 is the assembly, you'll need to drain the oil out first
Drain plug is #13, filter is #8 or 21 depending on which one you have
#8 is no longer serviced and I couldn't find a crossover for it
#21 is part # 7702218, replaced by # 86546604 $45
