Ford 555 backhoe mount specs
Hello; I have a 1978 ford 555 tractor loader and I wanted to put my backhoe from my ford 4500 on it. The 555 has mounts for a “bolt on” backhoe with holes for bolts and dowel at top.
The 4500 had the weight of the backhoe hung using hooks on the bottom. The backhoe has large round horizontal pins which engage in the hooks.
I am planning to make a 1” plate with hooks on top and bottom that bolt onto my 555 so the backhoe can hang in the new hooks.
Does anyone know where I might find a schematic for either the 555 or the 4500 mounting points to make it easier to design the hook locations? Or even a schematic of the backhoe mounting points?
Thank-you;
Mike
If you have both the tractor and the hoe, measure them up.
Also, check the plumbing at the rear to see how compatible they will be together. There should be a one inch power beyond line that goes from the pump around the left to the rear of the machine to feed the hoe controls and then the beyond goes to right front for the loader control.
