Ford 555B brakes
T 970
I'm looking at a 555b backhoe with bad brakes
looks to be out of adjustment anyone know how
much it will cost to have the brakes repaired l don't
have time to try to do this myself. Trying to make the deal before I can talk to repair shop.
If it's just an adjustment problem... that will take 1/2 an hour to adjust. If it needs brake discs.... between parts and labor you could be looking at 3-5k.... I haven't priced them lately but i'd expect hard parts to run you close to 2k if you need actuators. Best case would be probably 500 just for discs... However, unless the machine has very high hours or ran the wrong oil for years... or run out of oil... I doubt it would need discs. Just adjustment.
Rod
The machine don't show hi hours not sure the tach is right 1687 hrs not a lot of ware in pins at any joint
Rod if it would be ok could I send my number by email I would like to talk to about the 555B you if you have time.
Terry
