Anyone have suggestions on starter replacement for an early to mid 80s Ford 555b backhoe? I've read that some say putting in a gear reduction starter is much easier to get in (without having to remove injector pump, fuel filter, etc). If anyone has suggestions or recommendations on this I would really appreciate it. Any particular make / model #??
In addition,.... I'm having trouble starting my 555b. I'm in middle Tennessee and it's been highs of low 50s, lows in high 20s at night. . I've bled fuel lines from filter, through pump up to injectors. I've tried heating air intake with heat gun. It won't pop off. Starter is turning engine over but new and freshly charged battery doesn't last many attempted starts (10 or so) of 15-30 seconds each. Ether won't get it to start. Before I do compression tests,.... I am planning to redo battery cables (they appear original and probably significant resistance,..although I've not checked that specifically). I'm thinking that replacing the starter might be a good next step???
I believe that pump is ok as I'm getting fuel returning to the tank via return lines and when I bled lines,.... fuel amount seemed appropriate. I'm a bit surprised that it won't pop off even with Ether??? Makes me think that starter speed may not be enough for significant compression build up in cool temps??
Thoughts anyone?
Thank you for your time.
-KFD
Thoughts anyone?
-KFD
