Looking at a Ford 5640 SL with cab - 2wd. It grinds when shifting between forward/reverse. The clutch will stop the tractor - but it is as if the clutch won't "slow down" the transmission or stop the spinning. On further investigation -the clutch cable is broken. I have looked up the parts diagram, part is not too expensive or difficult to replace - but I have to buy it "as is". Question is does anyone know the purpose of the "clutch cable"? Does it act as some kind of transmission brake or is there likely a bigger problem. It is the 12 x 12 transmission. Clutch master cylinder was also leaking and I see a rebuild kit is available for that. It will shift thru the ranges and gears, just the F/R grinds. Trying to determine the chances if the cable is the simple fix or if the cable being broken is a result or sign of a bigger issue. Tractor has 4000 hours. No other apparent mechanical/engine issues and in otherwise good shape. Any insight much appreciated.
