Sailorjim01
Purchased my 600 a few months back and it was wired 6 volt. I have done a 12 volt conversion and it has only ran one time since and then I had to jump it because I found my neutral safety switch bad. Ordered a new one and found a previous owner had welded the shifter and shaft together making taking it apart a bigger job than I want to do at this time. I bought a momentary switch and mounted and wired it. It is obvious that I have wired some thing wrong. I replaced the 6 volt starter solenoid twice because I burnt it up. Directions say the starter and solenoid at 6 volts should work. I bought a 12 volt starter solenoid and if I understand correctly, 12 volt now needs sent to the S terminal on the solenoid and the grounding is from the mounting bracket. I have wired the coil wire thru the ignition switch. Seemed like a good way to do it. I ve attached a diagram. Not the best as I used my phone as my computer is down.
Any help would be greatly appreciated.
