Ford 600 front wheel alignment
Cludio
I have a Ford 600 that I replaced the steering column bearings on - my left front wheel is not in line with the right - how do I make adjusment to get the front wheels in line??
Are you meaning that the wheels are not straight when the steering wheel is straight or do you mean that one wheel is straight and the other is turning?
If the first problem, then re-do the sector gears (hard) or pop off the steering wheel and move it some (easy).
If the second problem, turn the drag links. You want to measure the distance from center to center of the tires at the mid point on the front and back. (the 3 and 9 o'clock positions) You want the front to be in a bit, like pigeon toed. About 1/2" is usually good.
