Ford 600 genny
TomN
.... just took my ford 600 Genny for rebuild... bearing bad in front plate.... knew it was going... SoundGuy had told me that 6.5 volts was low.... Genny started making bad noise.... shut down immediatley...as to avoid further damage... will cost about $45.00 from local guy to do.... will put out 7.1 volts when finished :) Arm. is good... no damage from being "out of line"... due to not running machine after noise was heard....
... need new PTO shaft for this machine also... as spline is bent....
(quoted from post at 16:41:49 02/20/13) .... just took my ford 600 Genny for rebuild... bearing bad in front plate.... knew it was going... SoundGuy had told me that 6.5 volts was low.... Genny started making bad noise.... shut down immediatley...as to avoid further damage... will cost about $45.00 from local guy to do.... will put out 7.1 volts when finished :) Arm. is good... no damage from being "out of line"... due to not running machine after noise was heard....
onder where those extra 0.6 volts will come from? Certainly not from bearing!
JMOR... he is going to fully tet genny after done... 2 brush system appeared to be fine, but hey, I am not a generator expert... I am sure I will know more "beyond" my reasoning, once he looks at it... lol
... I know some of the 9n and 8n generators had a 'high/low" adjustment.... this one does not... is there any credence to an adjustment in voltage regulator on a ford 640?
just curious
(quoted from post at 17:03:50 02/20/13) ... I know some of the 9n and 8n generators had a 'high/low" adjustment.... this one does not... is there any credence to an adjustment in voltage regulator on a ford 640?
just curious
es, VRs are adjustable. Joe Shadetree will not normally be successful in adjusting attempt, but a knowledgeable generator man can do. If he has both your VR & generator he will likely deliver as promised. :)
yup.
my guess is he had brush problems too.. as in no contact.
it's a wonder the fields aren't cut.. see that alot.
Genny is repaired and back on.... Tractor is back in service... damage was at a minimun, as I did not run it after realized issue... 2 days/45 bucks.... he had to solder something on the arm. replace front bearing... Brushes in great shape... now puts out 7+ volts... Volt reg fine... evrything is "nominal".... :)
(quoted from post at 16:30:38 02/22/13) Genny is repaired and back on.... Tractor is back in service... damage was at a minimun, as I did not run it after realized issue... 2 days/45 bucks.... he had to solder something on the arm. replace front bearing... Brushes in great shape... now puts out 7+ volts... Volt reg fine... evrything is "nominal".... :)
Grrreaat! :lol:
