ford 601 fuel line
SH IN MO
can anyone tell me where to find a metal fuel line for my 601 ford serial no. 79305 , would like it to be a factory fit. THANKS
The factory fuel line has a short piece of rubber hose crimped in between the 2 metal ends to allow for vibration. If you want all metal you can buy a pre-made section of 1/4" brake line and bend it to fit.
external_link has a metal line with a short rubber section in the middle. You'll need two small clamps to kinda custom fit it. Worked for me!
I just bought one for my 850 from Walt's Tractors. Steel with factory rubber section. I believe the 601 uses an all steel line. They list them. It is a CNH part and had it in three days. See link.
Fuel line
Best thing I found ( and a heck of alot cheaper price @$6) was right at NAPA -- just as you did from the brake and fuel line selection already fabbed w/correct/ male ends and all.
Steel Fuel line on 601 from Tank to Filter comes in two pieces with a coupler. The lower section is reasonable ($20), but the upper section is high from CNH $70-$80!
If you are capable of buying line and bending it yourself like was suggested...that would be a great option (and cheaper).
