ford 601 oil pump
replacing oil pump in my ford 601 tractor. left distributor in and pulled hex shaft out the
bottom with pump. planning on replacing the same way. my question is will pump prime on its
own? thaught about pulling coil plug boot off and spin it over with starter to see if is
going to build pressure. advise?
Before you install the pump, pour some oil into the inlet and spin it until it spits oil out the outlet. Pump is primed and you're good to go.
