Ford 620 Front End Loader
ras440
I have a 1956 Ford 620. I am looking for a Cylinder Packing Kit for the bucket cylinders. The lift model# is 19-97,Serial# 3304. I've heard that this lift is also a 730 or 750? Don't know, but need the kit to repair the Hydraulic Cylinders for the bucket. Anyone know where I can get a repair kit? Leaks bad and won't hold the bucket up. Thanks.
According to the parts site, 19-97 is a model 703 loader. The part number for a seal kit for the bucket cylinder is 251164. Should be available at any New Holland dealer for around $60.00 each. You'll need a kit for each cylinder. Third party after market kits are available on amazon and ebay for about $20.00 each, but I can't vouch for their quality or accuracy of fit for your application.
I just re-read your original post and I missed this the first time:
Is it the bucket cylinders that curl the bucket that you need the seal kits for, or the lift cylinders that lift the arms up?
The part number I gave you originally is for the kit for the bucket cylinders, which curl the bucket. If you need the kit for the lift cylinders it is part number 309853 and is also available from any New Holland dealer and is actually a bit less expensive, only around $35.00 per kit. Again, you will need a kit for each cylinder.
