Ford 640 ignition
Ramseyer35
I've got a 640 with positive ground 6
volt. I have the negative post of the coil
going to the distributor and the positive
to the ignition switch. Is that correct or
not? My manual says it is but can't
determine if it shows a positive ground or
not. I cant get the tractor to fire when
turning over but if I pull the plug I have
spark. But with all plugs in it won't fire
on gas or ether. And I've checked points
and timing already.
Old is correct, the wire from the distributor should be connected to the positive terminal of the coil. As you have observed that being reversed does not keep a coil from firing, the coil just produces a less than optimal spark. So is this a case of it ran before I messed with it? What else did you do to it? Have you had the distributor out of the engine since it last run?
For POS Ground the coils + goes to distributor and - gets power from ignition switch when ON. It can still spark if wired backwards but the system is less efficient
To figure out the cause of no spark try my Ignition Troubleshooting Procedure linked below.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
John Ts Ignition Troubleshooting
Have you checked to make sure you have a good blue/white spark at the center wire of the cap and at all 4 plugs wire that will jump a 1/4 inch gap or more??
Sorry, but please remember you are there looking at the tractor and we are just looking at the words you are typing. You say ..piecing it together for 3 months.. this still does not answer my question. More information please. If he had the engine completely tore down that would be good to know. This would likely mean the distributor has been off the engine. I started to reply asking if you know that a 4 cycle engine has the piston at top dead center two times within the 4 cycles. So if you just line up the timing marks or have the number 1 piston at top dead center the stick your distributor aligned to fire number 1 cylinder you may have it timed to TDC of the exhaust stroke instead of the compression stroke where it needs to be.
Could be with the plugs in and making compression, the starter is drawing away so much voltage there is not enough left to make spark.
A very common problem with 6v systems is trying to use automotive battery cables. They need to be heavy duty size 0 or 00, not the light gauge 12v cables.
A worn starter will also draw too many amps, robbing the coil of enough volts to spark.
Of course the battery must be fully charged and healthy. Everything must be right for a 6v system to reliably work!
If it has not been run in a while, try adding a teaspoon of oil to each cylinder to lube the rings and raise the compression.
Something you could try, temporary a 12v battery in just long enough to get it to fire. It won't hurt anything, just don't leave the ignition on or run it more than a minute or so, and don't marathon crank it! Do not try jumping it with the 6v battery still connected, it can damage or explode the battery!
If it still won't start, disable the spark, hold your hand tightly over the carb air inlet and give it a crank. You should get strong vacuum and your hand wet with gas. If no vacuum, there is a valve problem, likely stuck open. If vacuum and no gas, there is a fuel delivery problem or clogged main jet.
