Ford 640 rough running when hot
Scot Webb
I have a 1957 Ford 640 tractor that starts instantly and runs well until it gets hot. It then loses power then recovers over and over again. Like it is surging. I am pulling a finish mower mowing about 2 acres and had to stop 3 times and run cool water over the radiator and then it runs just fine until it gets hot again. It is not getting into the "red" section on the temp guage and it has been run hotter before and did not do this. Any suggestions?
Coil getting weak will cause problems like that. Advance in the distributor sticking/not working will also cause you problems like that. A clogged up cooling system also will cause that and the vent in the fuel tank clogged with
ditto what old said.
also.. bad fuel flow will cause that.
might be just enough flowing to keep the carb filled.. but under heavy load it falls behind then gets lean.. when you stop it to cool it off it fills the carb back up.
check fuel flow into a cup under carb.
post back... also.. 6v or 12v.. and if 12v.. does it have a 12v coil or a 6v coil and resistor?
soundguy
Thanks for the replies so far. It is a 6v system. I checked fuel flow a few months back for another issue and it was fine then but will check again.
Not like that. It would not start a few months ago and I wanted to make sure it was getting fuel because the spark was fine.
I had the same problem yesterday on my 640 bush hogging in the heat.
I did not like the rubber hose the PO had installed, so I re-routed the fuel line around the back by the battery tray and then forward to the carb. The last 12" of steel line goes right by the manifold, and was probably boiling the gas. So I cut a little piece of tin ducting and wired it onto the fuel line for a heat shield.
Farmerizing, sure, but no problems the rest of the day, and it was HOT in East TN yesterday.
Doug
Thanks for the info...I'll have to look how close the line is running to the exhaust. It was about 95-98 degrees when I was mowing.
