Mark Schmitt
I was able to buy a very used Ford 640. It will need a lot of work.
I just got it started after alot of electrical work. My problem is that it has a loud noise, similar to a hitting. It is also pressurizing the fuel tank. I am thinking it is a valve problem.
If anyone can help?
Though I cannot help much with the noise without additional information, the fuel tank should not pressurize and MUST have a vented cap.
The heat shield between the muffler and fuel tank MUST be in place.
Dean
As Dean say on the fuel tank and one like that can be very bad to the point of causing a fire.
As for the noise is it a knock sort of noise or more like a sewing machine. If it is a knock could be a rod bearing and if so do not run it till you have dropped the oil pan and made sure all the rods are nice and tight. Also what type of oil pressure does it have?? If real low that goes back the a bad rod also
Dean
The oil pressure is between 40 and 60 PSI.
The water temperature is 180 degrees.
The noise is in the block. I just finished checking the gaps, and all were within tolerances. The noise is still there! It isn't a sewing machine noise.
Thinks
My 640 sounds like a diesel when it idles.It uses no oil and runs 50 to 60 on oil pressure.Been that way for 24 years now.The fellow I bought it from thought it got new rings and bearings but old pistons were used.You might have valve noise, worn rocker noise.
Thanks, I just finished checking with a scope and the noise seems to be in cylinder 3. I plan to take a pressure reading tommorrow. There is oil gas fumes coming out of the vavle cover breather.
