Ford 641 pto removal
chevy9588
We are trying to pull the pro shaft out of a ford 641 but are having no luck. We have pulled the bolts out of the seal housing is there something internally that holds the shaft in? Any advice would be great thank you.
once you pull the 4 bolts, and have drained the diffy and hyd oils, then if the shaft doesn't pull out as an assembly with the bearing carrier, then do the following.
get a punch or screwdriver to slip thru the hole int he pto to give you something to tap on or tug on, and then take a ballpeen or drilling hammer, and tap ont he 4 bolt flange in a direction as to rotate it around it's pto shaft axis. this breaks the gasket or gasket glue bond.. and generally should let it pop right out with a tug.
tip. the shaft passes thru an inter sump seal so try to support the shaft coming out and when you re-stab it so that you don't hog the seal out.
Thank you for the tip. This has apparently been tried before because the ears on the rear plate have been broken off except for one. We tried sliding a bolt through the pro shaft and tapping on it that way but did not gain any ground. We removed the inspection cover where the engaging lever is and could not see anything stopping it from sliding out. For my next attempt I am going to get a slide hammer on the pro shaft somehow and see if it will come out that way. If that does not work I guess I will be going deeper into it to try to get it out. Thank you for the help.
did you get the flange on the bearing carrier to rotate? and rotate freely. it. tap on it while also tugging.
that is about thge ONLY think that will hold it in.. is the gasket surface and the OD to ID merger of the bearing carrier to the rear housing. aftr about a half inch it should just about fall right out..
