Ford 660 3 point hitch
I have a 660 that I brush hog my field with. This season after about an hour of mowing I noticed that the 3 point hitch was down in it"s lowest position and it wouldn"t raise. I parked the tractor for about an hour and tried to raise the hitch and it worked fine. After about an hour it slowly dropped again. This is the symptom. It works for a while and then gives up working. Any suggestions?
Thanks,
Terry
Most likely you have a bad leak, and when the oil is cold and thicker the pump is just able to keep the arms up, but once it heats up and thins out, it leaks too fast. If you remove the round cover on the left side of the rear axle housing where the PTO lever is you may be able to see it leaking with it running.
You might start by looking through the differential fill plug under the seat. The back edge of the ram cylinder is there and any leakage in the top cover/auxiliary hydraulic plate can be seen there too.
Don't think he can see anything through the differential fill plug. Think he might be able to see through the hydraulic fill plug, which is where he would see the lift cylinder if it can be seen through a fill plug.
