Ford 660 lunging
I bought a 660 last year and this is the first I have used it hard. I am mowing a 7 acre field. It has worked fine until tonight. I have been mowing for about 1 hour and the tractor is running pretty warm. Just out of the green in the white. It starts lunging and it gets so bad I could get whip lash. I have to push in the clutch, put the brush hog out of gear and move forward slowly. If I run it without the hog running it will straighten out and run smooth, but when I start to try to mow again it starts lunging. Any ideas?
Thanks,
Terry
Sounds like it might be running lean.
Have you checked the fuel flow?
You could try choking it a little to see if that helps.
Might just try opening the main jet a little as well.
Sure sounds like a fuel issue. Check the sediment bowl and clean it, check the line at the carb for flow, clean the screen in the elbow if it has one.
i agree with royse.
check fuel flow.. and check to see if a lil choke helps.
could pull and read plugs too, checking for lean/
hooging uses fuel.. you may be over running fuel supply if it has a clog.. etc..
Thanks guys. I have waited way too long to mow this field and there is seed and dust everywhere. I will clean the fuel system.
Terry
Make sure you clean the chaff and seed out of the radiator/grill too!
Blow it out with low pressure air will work, or rinse with a garden hose.
Gotta keep it running cool! :)
