Ford 6600 Tractor
dr0832
Hi, I am trying to find the approximate value of a Ford 6600 tractor with a snow blower attachment. I don't have the serial number currently or any other information, however, I believe this tractor is functional. Of course, I have checked online but prices are all over the place from $5k-$15k. I would appreciate any info.
I can’t help much with the value but I can tell you that tractor is a 81 model
Ford increased the engine size on the 4 cylinder tractors for the 81 model year, they called these tractors Blue Power Special’s, that one has the Blue Power Special decal on the bottom of the grill shell
I recently purchased a older 6600 at auction, the paint isn’t as good as that one but the tires have more thread, it is 2wd with no ROPS or canopy
I paid $6600 for mine but I feel I got a pretty good deal
I would value the tractor at around $8000-$9000 however in the photos the rear tires look to be worn down which would lower the value due to the cost of tires today
Snow blowers are a oddity in my area and I have no idea of their worth
Thank you. I found a bit more info. I tried to start it but it was just releasing smoke each time. Could this mean it needs the fuel replaced? I'm wondering if I should sell as is or get a mechanic to fix it.
Hours: 2800
Tractor #: C677473
Model: EA215M
Unit: 1J16B
Engine: 1G3A
Transmission: TFT9B
Tractor #: C677473 - This is a 1981 serial number.
Model: EA215M - This says that it is a 6600 with a diesel engine, independent dual speed 640/1000 rpm PTO and an 8x2 manual transmission with Dual Power.
Unit: 1J16B - The tractor was assembled on September 16 1981 during the day shift.
Engine: 1G3A - The engine was assembled on July 3 1981 during the midnight shift
Transmission: TFT9B - This is most likely 1F19B, which would mean that the transmission was assembled on June 19, 1981 during the day shift.
Few more photos
Definitely get it running as it’s worth a good bit more if it runs
You may need to give it a small shot of starting fluid, SMALL SHOT like half second or less
2 speed pto and dual power adds valve
Where is this tractor located
About 45 min north of Boston
