Ford 6610 flywheel
TKemp
Has anyone ever overhauled older Ford 6610 diesel and found different marks on flywheel for timing injector? There is no 23 degree mark on flywheel to use for timing. TDC compression stroke number one cylinder 0 degree on flywheel. Reversing engine by hand a filed mark on flywheel lined up on peep hole mark and align marks on injector gear and injector allows engine to crank but I think it is still off just a hair. Suggestion and advice and I know 23 degrees BTDC is correct setting but that doesn't help.
(quoted from post at 10:38:23 10/07/21)
Back the flywheel past the mark and come back to it
That gets the gear backlash out
Thanks will try that. The two grooves on injector were shown before I aligned them. Is there any movement of injector externally to fine tune it does not seem to me there is? In line Minimec.
(quoted from post at 12:04:36 10/07/21)
No external adjustments, loosening those three bolts and turning the pump drive on the gear is all the adjustment there is
Thanks again I didn't think so but never hurts to ask.
Did that but you have to also make sure timing mark on flywheel is set with injector timing mark. Unfortunately on this tractor there was no 23 degree BTDC on flywheel so we were kind of stabbing in the dark.
Did that but you have to also make sure timing mark on flywheel is set with injector timing mark. Unfortunately on this tractor there was no 23 degree BTDC on flywheel so we were kind of stabbing in the dark. Thanks though.
