Ford 6610 fuel
Just installed a injection pump on my Ford 6610 and it's not getting fuel to the injectors it came of a different tractor but ran with no issues
Did you bleed the fuel system to the pump?
Did you crack the high pressure lines loose at the connections to the injectors and watch for fuel dripping out of the connections while cranking the engine (throttle open at least halfway and the shutoff in the run position)?
When did the engine, this pump was removed from, last run?
