Ford 6610 info
TKemp
Need info on Ford 6610 model #EA314C, engine #1L23A, tractor #C68231, unit# 2B13B. Can't seem to clearly identify engine. Tractor has a hydraulic oil cooler mounts in front of radiator can't seem to find replacement. This was not add on came from factory with oil cooler. Hydraulic pump# 1L11B. Any info would be appreciated.
e1nn7a095aa12m is a cooler that was used on some. The new part number is 83945933. But it may require modifications as its a newer part used on newer tractors.
http://www.link_disallowed/acatalog/UCA999996-Transmission-Oil-Cooler---Replaces-83945933--E1NN7A095AA15M-124143.html
Model EA314C is a 6610 all purpose with diesel engine, independent 540 pto and 8x2 manual trans
Unit # 1L23A = tractor was built Nov 23 1981 on midnight shift
Serial # C68231 is for a 82 model tractor built in the US
Production started with serial # 68200 so yours is the 31st tractor built for the 82 production model.
The oil cooler your looking for is NH # 83945933 - $333
I would try finding a aftermarket transmission cooler I could adapt to make fit
Thanks for info. I took information found under the hood of tractor. Interested in more info on engine. The 1L23A was listed next to engine number although Yesterdays Tractor staff could not identify engine with that number. Also what is the unit # 2B13B stand for? I have decided to take the oil cooler to radiator shop that just finished radiator and have them try to repair it.
Sorry I messed part of that up
Engine # 1L23A is the date the engine was assembled which was Nov 23 1981
The unit number is the date the tractor was assembled which was Feb 13 1982 on day shift
The engine is a 268 ci 4 cylinder diesel, for any parts you may need refer to it being a 82 model
Ford made several changes to the 10 series models in 86 and called them the Series II
