Ford 6610 Neutral Switch
David G
I have a new neutral switch to put in on my 6610 II with the 8 speed on the tree. Are there other parts to order, or things to look out for when changing this?
I'm not sure where the switch is located on your particular tractor... but if it's under the transmission cover where most of them are, you best get a new gasket for the transmission cover. Other than that it should be fairly straight ahead.
I think if yours is an open station the switch is on a shift rail in the transmission... however, if it has a factory cab it will likely be on the clutch pedal...
Rod
So it would appear my thoughts apply to the 8x2 tranny but not the 8x4 synchro. Cab or open matters not.
I think... they type of cab matters and mabey the vintage. I know my 7710 has it on the pedal. I think that was more a flat deck thing. I also think the earlier straddle Q's probably had the switch in the transmission while later ones were probably changed to the pedal... and possibly the serial prefix plays into this as wiring was the major difference between them...
What I do know is all open stations I've seen have had the switch in the TM and cabs that I have are on the pedal...
Rod
I must have had a bad day yesterday. My comments should have referred to the 6710 and 7710, flat deck tractors having the NSS at the pedal. Straddle mount 6610 and 7610 tractors will have the NSS in the tranny. Sorry for muddying the waters so much.
