Ford 6640 cab question
Royz28
I recently got a Ford 6640 with a cab and am trying to re-do some of the cab. The rear window has a rubber seal that was glued around the perimeter of the edge, doesn't extend or cover the edge. I am having trouble finding the seal and wondering if it is actually the original seal. I was hoping someone with this series tractor with cab could tell me if the rear glass molding glues around the interior edge or does it extend over the edge?
looked at 5640 cab yesterday. it has a moulding attached to the glass that goes all the way around the window... the rubber moulding fits on both sides of the glass edge, with a notch in it for the glass... the out side looks more like a hard plastic finish, while the inside part of it looks like a modern soft car door seal of thick, compliant rubber with nice bulge in it. There is nothing on the window frame other than steel and paint, so the glass moulding does all the work very well.
assuming you have the same one piece window that my cab has. It is significantly better than the previous 7710 II cab.
Thank you. What's on there now is just along the interior edge and was glued on by the previous owner.
The top hinges are offset for the rubber gasket...a gasket that might be 3/8 or better of the cushy rubber stuff.
In a pinch universal trunk gasket off ebay??? and some really really good glue.
