I have a ford 6700 tractor 8 speed with high and low transmission. Was bush hogging a few weeks back and put the tractor in reverse to back up and ended up getting the tractor stuck in reverse. I can get the tractor in the neutral position by putting the high and low range gear in neutral. I can also shift into all forward gears.... when I do this the tractor does not want to move and will choke down almost like the park brake is on. I cannot shift into reverse now at all but as stated above the tractor still stays stuck in reverse. Thought it could possibly be stuck in two gears at once any help would be greatly appreciated!
