Ford 7000 not charging.
bAlatonmMN
Its got all new cabels, the battery is farlly new, and my uncle said that the alt is new.
It has a Motorola alt if it helps any.
Any other Ideas?
New alternators fail. Take it down to Auto Zone or a Starter/Alternator shop and have it checked.
Full field (apply battery voltage to the field terminal) the alt and see what voltage it makes at the battery. It should be 14+.
If it produces with full field then I'd say there's a wiring problem or more likely a regulator problem...
There are so many very good reasons to fire away those old alternators and install an internally regulated Delco 10si or something similar. You eliminate several wires and an external reg that does fail.
The fact that the Delco is about 1/3 the price is only one...
Rod
My experience has been that the alt is good, but the regulator dies. Sometimes lets the battery go dead, sometimes overcharges it. Have a regulator ordered for my 7000 right now, replaced the one on the 4600 last year. About $70.
