Michael Morin
I have a 723 backhoe and it has those special ford threads on the hydraulic lines I need to replace lines and none of the hydraulic shops around here have these fittings any help would be awesome thank you
(quoted from post at 04:21:13 05/09/12) Here are few links. Any good hydraulic supply place sells the BSPT (British Standard Pipe Thread) and BSPP (Britsh Standard Parallel Pipe) adapters. You'd have to be nuts, or in a real hurry to fix any other way.
This explains further:
BSPT (British Standard Pipe Thread) is similar to NPT except for one important difference. The angle across the flanks of threads (if you sliced the fitting in half long-ways and measured the angle from root to crest to root) is 55 degrees instead of 60 degrees as it is for NPT. Thus an NPT male will fit into a BSPT fitting or vice versa but they will not seal. This is a popular fitting in China and Japan but is very rarely used in North America unless the equipment to which it is attached was imported. Thread sealant is needed to seal the male and female fitting together
BSPP Connections
BSPP (British Standard Parallel Pipe) is most popular in the UK, Europe, Asia, Australia, New Zealand and South Africa. It is a parallel thread fitting that uses a bonded seal ring to do the sealing. This bonded ring seal is sandwiched in-between a shoulder on the male fitting and the face of the female fitting and is squeezed in place. BSPP pressure gauges have a longer male thread and use a copper crush washer that is squeezed in between the bottom of the male fitting and the bottom of the female BSPP hole forming a pressure tight seal. No thread sealant is needed to form a seal
http://www.ralstoninst.com/news/the-difference-between-npt-bspp-and-bspt-seals
http://www.highspeedpc.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=BSPadaptor&Category_Code=Fitting
http://www.metricmcc.com/catalog/Ch8/8-853.pdf
(quoted from post at 13:52:19 05/09/12) I talked with TISCO who made those adapters and they are no longer made.
There is a new adapter CU878MJ that will work it is a 7/8” male JIC x 5/8” o-ring port steel adapter.
They said it was the same thing except it goes to JIC and not NPT.
I have the remaining stock and some of the new ones coming and should be here today (I hope)
do you have flow restrictors on your lift/crowd circuit or is that a waste of time??(quoted from post at 18:01:14 05/11/12) Hello Andy , I have also collected up all of the original Ford hoses I could get my hands on over the years but the 4 boom hoses I have to make the most of . I have also had good luck CAREFULLY CUTTING the original hoses apart to save the original fittings to reuse them with new crush collars . What ever works to keep them running . Thanks Tony
