ford 7700 pto
soderbeck
I have a ford 7700 tractor that the pto keeps running even when shut off but no power to it. What does it take to fix this?
I think your clutches are bad, or Iv been told they well turn when its cold out because of the grease or thick oil in there. I forgot what its called.
I believe there is a piston that is actuated by hydraulic pressure that engages the clutch. It may not be releasing all the wayso it allows the saft to turn but not transmit power. Bern, Rick B, or RodinNS can probably give you more info on this so ask your question in the Ford Forum
Likely a bad brake band if there's no 'power' on the shaft.
Ofcourse, 'likely' can be a big word.
It would be wise to tap into the clutch supply circuit at the bottom of the pump and take a pressure reading. It should make 160-180 psi at a fast idle with warm oil (operating temperature). Check with the PTO engaged, then disengaged, then with the Dual Power in low, then high... and if it's got FWD, check that engaged/disengaged as well. Check ALL possible combinations so you make sure there's no leaks.
It'll probably be OK... as I think it's the band anyway, but CHECK.
Probably the easiest way to change the brake band is by removing the lift cover, not that it's overly easy...
Rod
Typically, the little hyd pump that runs the pto gets weak.
This lets the brake slip, so the brake wears out.
It does the same amount of slipping as you engauge it, because the same hyd pump locks the clutches together. So, the clutches get hot & wear/warp.
We don't notice it/ bother about it until the pto won't work unless we speed up the engine. It slips at low rpms. (Just a weak hyd pump....)
So, pick your poison, once you start digging into it, where do you stop? :)
Start with the hyd pump pressure, as that will be low. Likely the brake is also worn up now as it slips. Likely the clutch pack itself is getting worn, and 1/2 way to needing replacing.
Do you fix it now, or let it all wear out fully for several more years so you get your money's worth out of it? :)
--->Paul
