Ford 800 won't shut off
dsolsbery
Rewired my 800 ford tractor using John in La"s diagram and everything worked fine until I tried to turn it off. The tractor kept running. I finally had to choke it to kill it. I double checked the wiring and it looked good. Any suggestions?
Thanks,
dsolsbery
(quoted from post at 16:27:18 09/15/12) Rewired my 800 ford tractor using John in La"s diagram and everything worked fine until I tried to turn it off. The tractor kept running. I finally had to choke it to kill it. I double checked the wiring and it looked good. Any suggestions?
Thanks,
dsolsbery
ell, it looks like that has been over an hour ago, if the times/time zones are alright, so something in wirung is probably hot or drained battery by now. If battery not dead, then start pulling off wiring from coil, working back toward switch, battery, etc. until you find where the power is not being switched off.
NEVER MIND! I found the problem. I didn't place the warning light in the #1 alternator wire. Just call me Mr. Potato Head.
(quoted from post at 16:49:51 09/15/12) NEVER MIND! I found the problem. I didn't place the warning light in the #1 alternator wire. Just call me Mr. Potato Head.
reat! Good sleuthing.
