Ford 841 Electrical Problems.
Nek58
Having electrical problems. Tractor will not turn over. Battery is charged. I tried replacing the starter solenoid but no luck. What can I check next?
Thank you, Ken
6 or 12 volt?
Battery cables clean on both ends?
Ground cable connected to the chassis, not sheet metal.
Original safety starter button or key start?
Part number of the new solenoid?
It makes a difference which solenoid post the battery wire goes on for some solenoids using the original starter button.
With the tractor in neutral, have you tried a jumper wire to ground or power the start terminal of the new solenoid? If it works when grounded it would be right for the original starter button. If it works when power is applied, it is the wrong solenoid to use with the original starter button.
12volt.
Starter turns over when it bypass the solenoid.
Will this solenoid work from Tractor Supply?part #23677499
12volt.
How did you bypass the solenoid, by going direct to the starter with a booster cable or such?
Did you try using the jumper wire as I suggested? What was the result when grounding the S terminal? What was the result wwhen you put battery power to the S terminal?
From the description of that solenoid on the TSC site I am going to say it will not work with the original starter button (by the gearshift). I blieve to requires power applied....
23677499 Is the wrong solenoid.
That solenoid is for the 1965 and newer thousand series.
You need solenoid 311006
If everything else was working correctly putting that thousand series solenoid on your tractor should make the motor crank as soon as you turn the key on.
With this in mind I’m going to guess your original solenoid is not bad. Your problem is you are not getting power from the key to the solenoid. Most likely a bad key switch.
Checking for power at the solenoid on the wire coming from the key (small wire on right as you look at the solenoid) with the key on will prove me wrong or right.
Hi,
I FINALLY found a key switch that matches the one that was on the tractor. I hooked it up and no progress. I put the starter solenoid that was on there when I started having problems and tried to start the tractor again. Nothing. I checked the battery and it was dead. I jumped from the battery side of the starter solenoid to the frame with a jump box with the new key switch turned on and pushed the starter button and the tractor turned over. I need to wait until my battery charges and try to start the tractor later. I'll let you know how I make out.
Question, does the starter solenoid ground from the mounting bracket to the tractor where it bolts on?
The nuts do not tighten down very well.
I put those tooth lock washers on my solenoid mounting bolts to bite in for a good ground.
