Iceman214406
Hello all,
I am a little confused on how the fuel system is flowing on my 850. I see a steel fuel line running from the shut-off, down by the muffler, then goes to a rubber hose and into the sediment bowl. I am seeing images online where the sediment bowl inlet faces the engine block and the steel fuel line is threaded directly into that without the rubber hose. Mine is facing away from the block - is that the way it is supposed to be for the 850s or did someone reinstall my sediment bowl backwards? Thank you.
