I recently bought an adaptor kit for my ford 850.(part number S.68981) I removed the stock plate(it uses 5 bolts), cleaned all surfaces and mounted the new plate (only uses 4 bolts). I can not seem to get the plate to seal correctly. All surfaces seem straight and true and mounting holes line up perfectly. With the tractor running I have no leaks, but as soon as I use the remotes, I get some pretty good leakage between the two mounting surfaces. I have taken the valve body off 4 times, checked orings (even changed orings)and surfaces and have had no luck sealing the two faces. Once seated, the plates are firmly attached to each other with no obvious distortion.Any suggestions would be greatly appreciated.
Description: Single Spool, Single/Double Acting with Hoses - Female Couplers. For models: Ford up to 1965: 600, 700, 800, 900, 601, 701, 801, 901, 2000, 4000. After 1965: 2000, 3000, 4000, 2600, 3600, 3900, 4100, 4600, 2310, 2610, 2810, 2910, 3610, 4110, 4610, 3230, 3430, 3930, 4630
REMOTE CONTROL KIT Part Number S.68981
Ford 800 Series tractors include models 800, 820, 840 and 850.
