Ford 850 PTO Leak
smahler
The other day I was out mowing with the brush hog and today there was a puddle under the tractor and the leak was coming out right at the PTO shaft.....My question is "Is this a leak due to just the gasket or, more likely, the seal and thrust bearing?" Also, how hard are these parts to replace? I have a feeling that seal is gonna be a bear since it looks like its way back in there. Any help would be much appreciated.
Thanks,
Shawn
The seal that is "way back in there" seals the hydraulic fluid from the rear axle fluid. If it is leaking the fluid does not drip out.
There is another seal just behind the metal housing that carries the bearing. You can remove the PTO shaft and replace that seal or you can just buy a new PTO shaft assembly and replace the entire assembly.
with the tractor off, grab the pto shaft and see if it has in / out or up/down/side/side movement.
up/down/side/side movement means a bad bearing, and that in turn will hog the seal out.
in/out movement is a bad bearing, slipped or broke snap ring, damaged bearing carrier or wear ring. and will allow the pto shaft to walk out of engagement and damage the shaft and / or coupler.
If it is just the seal and the bearing is ok.. it's real easy to change out.
either drain rear end oil or drive tractor nose down into a ditch.. or jack the rear up.. put the 4 bolts and slide the pto shaft out. Note.. on a hundred series liek this, you will get rear and hyd oil mixing.. if it's all utf.. don't worry about it..
slide shaft out.. scrape off old gasket from tractor and pto flange.
remove big split ring from id of back carrier right up against the bearing, lay a piece of wood on the ground, and grab the pto shaft end that slides intot he tractor and tap down smartly ont he wood a few times and the flange with the seal will drop off.. drive the seal thru with a large socket, and reseat the neaw seal the same way.. lube the seal with grease and slip the pto shaft back into the flange, reinastall the split ring and then the shaft to the tractor with a new gasket.
maybee take 15m if you have the seal and gasket on hand.
check oils and go.
soundguy
