Hi guys. I have a 1955 Ford 850, 5 speed, 12 volt system. I worked it for about an hour grading my roads this morning with no problems. I shut it down for lunch, then went back to work. After about 5 minutes, it stalled. It didn't sputter or cough like it was starving for gas, just quit.It would crank but not start. I checked the gas tank, fuel lines, and carb. Plenty of fuel.
After a few minutes it started right up and ran fine for another 30 minutes or so. It then stalled again. Again, after a few minutes it started right back up. It stalled a few more times throughout the afternoon, and each time, after a few minutes it would start right back up.
Since I had plenty of fuel getting to the carb, I assume electical. The wires to each plug are seated tightly, and all plug wires to the distributer are tight. The wire from the coil to the distributer is tight. However, the coil was hot to the touch.
Since it didn't sputter, I don't think the plugs are bad. Do you think the coil is breaking down? What esle might it be?
Any ideas would be appreciated.
Dan
Dan
