Ford 850 Tractor
Kellar
Can someone explain the oil canister off the tube from the carb. How much oil and what type? Cleaning procedure? How it works and what is needed to clean and replace fluid.
this is yer air cleaner, clean cup and fill with same as engine oil to line. also with cup off it may be necessary to clean wire mesh up inside housing.
That is not an oil canister it is your oil bath air cleaner. Sort of sounds like you need to buy a manual or 2 so as to be up on what you need to do and or of course keep reading what is said here because there is tons of info here.
