My tractor starts OK, runs 30 to 60 seconds maybee more and than quits. Sometimes it will start again right away and sometimes later. Than it does the same thing again. I don't take it out of the barn since I know it is going to quit. I have ordered a new float and carb repair kit. Am I on the right track?
Thanks
Check that rubber gas line you mention in another post to see if it is clogged up. Other wise float valve is first to suspect..a speck of dirt in float valve...
If the rubber line is failing internally, you may have small pieces of rubber clogging the fuel inlet/float needle. The line near the exhaust could be causing the internal flaking.
Kent
Check for slow flow from the fuel tank- sounds like its running just long enough to lower the level of the sediment bulb to where fuel isn't flowing on to the carburetor, and not being replenished fast enough from the tank. Can you see the top of the fuel level in the bulb when it quits?
