Ford 860 or 850
grizz665
Is this a 860 or 850 ford .I was thinking 860 clutch looks like it's straight up.
There's a flat spot above and behind the starter on which the model number will be stamped. On the X60 models, the clevis on the clutch pedal rod has two holes. From the position of the clutch pedal one might guess it's a 860, but the numbers will tell you for certain.
Haven't looked at tractor yet . Just going by the pictures . 850 clutch pedal don't go up like that does it?
The pedal looks way high even for a 860 - why it's adjusted to that position is another mystery. There's really only one way to tell for certain what it is and that is to ascertain the model number stamped in the housing.
I tried to take a similar photo of my 860. I don't know if there's enuf info showing to tell 860 or 850 from this angle.
