172ci Engine rebuilt and first start I'm getting 50 psi on the gauge. Takes ~10 to build pressure. The bigger issue is that there is very little oil flow to the rocker arm. It takes about 20 seconds for the rocker arm shaft to fill and then just dribbles out of the short drain back tube. There is no oil pressure to speak of at the top end. No spraying or splashing around to lube the valve springs or lift rods. So, 50 psi on the gauge, oil level good, grommet on feed tube is new and fully seated when installed, tubes are not plugged. Has anyone had this issue and found the problem? This weekend I plan to pull the pump and see if I can find a piece of debris that may be restricting the feed to the tube. Maybe direct some air into the circuit to see if everything is open. Any insight before I dig deeper would be appreciated.
Kurt J.
Kurt J.
