Hello putting back together my 1961 861 Ford with the four-cylinder diesel I put all new fluids in today first fire up everything is fine I still have it on jackstands but, sitting idling the right rear axle spins very slowly than when I put it into a gear in mind you all the shifting works as it should only the one side continues to spin by the very slow pace even when I engage the throttle as if nothing is happening any ideas on what this could be? I havent messed with anything inside the transmission just a simple fluid change the 2 gallons of the 80 weight
